工具:3毫米六角扳手、十字螺丝刀anti-static gloves
1. Loosen the 4 screws on the rear panel with a 3mm hex wrench and remove the rear panel;
2. Find the PCB board that needs to be replaced, pull out the wire in the board, and then loosen the screw for replacement.
