1. Go to革命制度党nt Settings, ClickMore, findExtrusion WidthunderOther Optionssection, select the desired value available in the dropdown menu.
For instance: The model’s wall thickness is 1mm, choosing 0.5mm extruder width would be the most ideal value to fill the wall.
2. There will be a defaultExtrusion Widthvalue for each differentLayer Thickness。但是,您可以调整Extrusion Widthmanually in the range of -0.15mm to +0.25mm, and the value cannot be 0.7 times smaller than the default settings.
